Aller au contenu principal
JBL Charge 2 Plus Passive Radiators Replacement
Ce dont vous avez besoin
  1. JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: étape 1, image 1 de 2 JBL Charge 2 Plus Passive Radiators Replacement, Passive Radiators: étape 1, image 2 de 2
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Passive Radiators Replacement: étape 2, image 1 de 3 JBL Charge 2 Plus Passive Radiators Replacement: étape 2, image 2 de 3 JBL Charge 2 Plus Passive Radiators Replacement: étape 2, image 3 de 3
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Passive Radiators Replacement: étape 3, image 1 de 2 JBL Charge 2 Plus Passive Radiators Replacement: étape 3, image 2 de 2
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Passive Radiators Replacement: étape 4, image 1 de 1
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Passive Radiators Replacement: étape 5, image 1 de 3 JBL Charge 2 Plus Passive Radiators Replacement: étape 5, image 2 de 3 JBL Charge 2 Plus Passive Radiators Replacement: étape 5, image 3 de 3
    • Repeat Step 2, 3 and 4 for the other passive radiator.
7 autres ont terminé cette réparation.
John Reynolds
Membre depuis le 10/16/15
3 134 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-1, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 membres
12 tutoriels rédigés
3 commentaires
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Jomon johny - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 39
Total : 17,583
