Aller au contenu principal
JBL Charge 4 Speaker Replacement
Ce dont vous avez besoin
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: étape 1, image 1 de 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Speaker Replacement: étape 2, image 1 de 2 JBL Charge 4 Speaker Replacement: étape 2, image 2 de 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Speaker Replacement: étape 3, image 1 de 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: étape 4, image 1 de 2 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: étape 4, image 2 de 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Speaker Replacement: étape 5, image 1 de 2 JBL Charge 4 Speaker Replacement: étape 5, image 2 de 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: étape 6, image 1 de 2 JBL Charge 4 Speaker Replacement, Speaker: étape 6, image 2 de 2
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: étape 7, image 1 de 1
    • Gently pull out the speaker.
  8. JBL Charge 4 Speaker Replacement: étape 8, image 1 de 2 JBL Charge 4 Speaker Replacement: étape 8, image 2 de 2
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
10 autres ont terminé cette réparation.
Rohith Dara
Membre depuis le 01/24/19
357 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G1, White Winter 2019 Membre de l'équipe Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 membres
26 tutoriels rédigés
11 commentaires
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Réponse
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 42
30 derniers jours : 210
Total : 22,945
