Aller au contenu principal
JBL Charge 5 Speakers Replacement
Ce dont vous avez besoin
  1. JBL Charge 5 Speakers Replacement, Fabric Case: étape 1, image 1 de 3 JBL Charge 5 Speakers Replacement, Fabric Case: étape 1, image 2 de 3 JBL Charge 5 Speakers Replacement, Fabric Case: étape 1, image 3 de 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Speakers Replacement: étape 2, image 1 de 3 JBL Charge 5 Speakers Replacement: étape 2, image 2 de 3 JBL Charge 5 Speakers Replacement: étape 2, image 3 de 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Speakers Replacement: étape 3, image 1 de 3 JBL Charge 5 Speakers Replacement: étape 3, image 2 de 3 JBL Charge 5 Speakers Replacement: étape 3, image 3 de 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Speakers Replacement, Speakers: étape 4, image 1 de 3 JBL Charge 5 Speakers Replacement, Speakers: étape 4, image 2 de 3 JBL Charge 5 Speakers Replacement, Speakers: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the four 16.5 mm screws on the corners around the oval speaker.
  5. JBL Charge 5 Speakers Replacement: étape 5, image 1 de 3 JBL Charge 5 Speakers Replacement: étape 5, image 2 de 3 JBL Charge 5 Speakers Replacement: étape 5, image 3 de 3
    • Gently use your hands to undo the flaps located at the top of the speaker.
    • Grip the speaker on the top and bottom left of the square platform.
    • Gently remove the speaker from the casing.
    • Be careful of the wires attached to the back of the speaker when removing.
  6. JBL Charge 5 Speakers Replacement: étape 6, image 1 de 3 JBL Charge 5 Speakers Replacement: étape 6, image 2 de 3 JBL Charge 5 Speakers Replacement: étape 6, image 3 de 3
    • Holding the speaker firmly in place, gently remove the red wire from the speaker by pinching it at the silver base near the connection and pulling.
  7. JBL Charge 5 Speakers Replacement: étape 7, image 1 de 2 JBL Charge 5 Speakers Replacement: étape 7, image 2 de 2
    • Repeat the previous step for the black wire.
  8. JBL Charge 5 Speakers Replacement: étape 8, image 1 de 3 JBL Charge 5 Speakers Replacement: étape 8, image 2 de 3 JBL Charge 5 Speakers Replacement: étape 8, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the two 16.5 mm screws in the small round speaker's top right and bottom left corners.
    • Gently use your hands to grip the speaker and remove it from the device.
  9. JBL Charge 5 Speakers Replacement: étape 9, image 1 de 2 JBL Charge 5 Speakers Replacement: étape 9, image 2 de 2
    • Pinch the white wire gently at the silver base near the connection.
    • Carefully disconnect the wire from the speaker by pulling it.
  10. JBL Charge 5 Speakers Replacement: étape 10, image 1 de 2 JBL Charge 5 Speakers Replacement: étape 10, image 2 de 2
    • Repeat the previous steps for the black wire.
    • Both speakers should be properly detached.
Kat Whaley
Membre depuis le 09/13/23
753 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 32
30 derniers jours : 146
Total : 756
