Aller au contenu principal
JBL Charge Button Membrane Replacement
Ce dont vous avez besoin
  1. JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: étape 1, image 1 de 3 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: étape 1, image 2 de 3 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: étape 1, image 3 de 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Button Membrane Replacement: étape 2, image 1 de 2 JBL Charge Button Membrane Replacement: étape 2, image 2 de 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Button Membrane Replacement: étape 3, image 1 de 2 JBL Charge Button Membrane Replacement: étape 3, image 2 de 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Button Membrane Replacement: étape 4, image 1 de 2 JBL Charge Button Membrane Replacement: étape 4, image 2 de 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Button Membrane Replacement: étape 5, image 1 de 2 JBL Charge Button Membrane Replacement: étape 5, image 2 de 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Button Membrane Replacement: étape 6, image 1 de 2 JBL Charge Button Membrane Replacement: étape 6, image 2 de 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Button Membrane Replacement: étape 7, image 1 de 2 JBL Charge Button Membrane Replacement: étape 7, image 2 de 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Button Membrane Replacement, Motherboard: étape 8, image 1 de 1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Button Membrane Replacement: étape 9, image 1 de 2 JBL Charge Button Membrane Replacement: étape 9, image 2 de 2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Button Membrane Replacement: étape 10, image 1 de 1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Button Membrane Replacement: étape 11, image 1 de 2 JBL Charge Button Membrane Replacement: étape 11, image 2 de 2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Button Membrane Replacement, Button Membrane: étape 12, image 1 de 1
    • Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
  13. JBL Charge Button Membrane Replacement: étape 13, image 1 de 1
    • Gently pull out the button membrane. You should not expect much resistance.
4 autres ont terminé cette réparation.
Jake Bertholf
Membre depuis le 04/01/15
366 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 membres
11 tutoriels rédigés
2 commentaires
conseguiste el boton de repuesto?
Mario A Vargas S - Réponse
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
Joe Durand -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 20
Total : 9,583
