Aller au contenu principal
JBL Clip 2 Carabineer Mount Replacement
Ce dont vous avez besoin
  1. JBL Clip 2 Carabineer Mount Replacement, Carabineer Mount: étape 1, image 1 de 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Carabineer Mount Replacement: étape 2, image 1 de 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Carabineer Mount Replacement: étape 3, image 1 de 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Carabineer Mount Replacement: étape 4, image 1 de 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Carabineer Mount Replacement: étape 5, image 1 de 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Carabineer Mount Replacement: étape 6, image 1 de 1
    • Slightly move the motherboard to the side to reveal the sides of battery, carefully using the blue plastic opening tool, remove the battery from the speaker casing.
    • Be careful not to disconnect any soldered wires connected to the motherboard and speaker casing.
  7. JBL Clip 2 Carabineer Mount Replacement: étape 7, image 1 de 1
    • There are two 3 mm T8 screws holding the carabineer in place, remove these two screws.
3 autres ont terminé cette réparation.
Michael Hong
Membre depuis le 02/01/17
1 014 Réputation
5 tutoriels rédigés
Équipe
UW Tacoma, Team 2-2, Rose Winter 2017 Membre de l'équipe UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 membres
7 tutoriels rédigés
2 commentaires
i want to find that part ,dou you have web link to by
breakdancesok - Réponse
where can i find this piece please
Daniel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 81
Total : 8,763
