Aller au contenu principal
JBL Flip 2 Auxiliary Port Replacement
Ce dont vous avez besoin
  1. JBL Flip 2 Auxiliary Port Replacement, JBL Flip 2 Outer Case Disassembly: étape 1, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement, JBL Flip 2 Outer Case Disassembly: étape 1, image 2 de 2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
  2. JBL Flip 2 Auxiliary Port Replacement: étape 2, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 2, image 2 de 2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
  3. JBL Flip 2 Auxiliary Port Replacement: étape 3, image 1 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 3, image 2 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 3, image 3 de 3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
  4. JBL Flip 2 Auxiliary Port Replacement: étape 4, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 4, image 2 de 2
    • Peel the black rubber piece from one end to the other.
  5. JBL Flip 2 Auxiliary Port Replacement: étape 5, image 1 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 5, image 2 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 5, image 3 de 3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
  6. JBL Flip 2 Auxiliary Port Replacement: étape 6, image 1 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 6, image 2 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 6, image 3 de 3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
  7. JBL Flip 2 Auxiliary Port Replacement: étape 7, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 7, image 2 de 2
    • Expand the metal casing and carefully slide it off the speaker.
  8. JBL Flip 2 Auxiliary Port Replacement: étape 8, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 8, image 2 de 2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
  9. JBL Flip 2 Auxiliary Port Replacement: étape 9, image 1 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 9, image 2 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 9, image 3 de 3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
  10. JBL Flip 2 Auxiliary Port Replacement: étape 10, image 1 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 10, image 2 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 10, image 3 de 3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  11. JBL Flip 2 Auxiliary Port Replacement: étape 11, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 11, image 2 de 2
    • Use the black spudger to disconnect the speaker cord from it's socket.
  12. JBL Flip 2 Auxiliary Port Replacement: étape 12, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 12, image 2 de 2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
  13. JBL Flip 2 Auxiliary Port Replacement: étape 13, image 1 de 1
    • Carefully remove the cable connecting the control chip to the motherboard.
  14. JBL Flip 2 Auxiliary Port Replacement: étape 14, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 14, image 2 de 2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
  15. JBL Flip 2 Auxiliary Port Replacement: étape 15, image 1 de 1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
  16. JBL Flip 2 Auxiliary Port Replacement, Auxiliary Port: étape 16, image 1 de 1
    • Remove the one 7.0 mm Phillips #1 screw that connects the I/O board to the casing.
  17. JBL Flip 2 Auxiliary Port Replacement: étape 17, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 17, image 2 de 2
    • Remove the cord that connects the I/O board to the motherboard.
    • Put the motherboard to the side.
  18. JBL Flip 2 Auxiliary Port Replacement: étape 18, image 1 de 2 JBL Flip 2 Auxiliary Port Replacement: étape 18, image 2 de 2
    • With the black spudger, carefully wedge out the I/O board.
    • Be careful not to damage the I/O board with the black spudger.
  19. JBL Flip 2 Auxiliary Port Replacement: étape 19, image 1 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 19, image 2 de 3 JBL Flip 2 Auxiliary Port Replacement: étape 19, image 3 de 3
    • Gently pull the I/O board out from the speaker.
  20. JBL Flip 2 Auxiliary Port Replacement: étape 20, image 1 de 1
    • Desolder the auxiliary port to remove it from the I/O board..
    • Check out IFixit's official soldering guide for help with these special projects.
    • Soldering iron will be very hot.
Jonathan Wear
Membre depuis le 02/09/16
1 220 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 11-2, Cheng Spring 2016
USFT-CHENG-S16S11G2
4 membres
8 tutoriels rédigés
2 commentaires
Is It hard to repair ? I have one that is not charging, I don't know if is the battery or the usb port.
Renan Rufino - Réponse
Where can I purchase the auxiliary port (preferably in Europe)?
Eva Persson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 30
Total : 5,716
