Aller au contenu principal
JBL Flip 2 Battery Replacement
Ce dont vous avez besoin
  1. JBL Flip 2 Battery Replacement, JBL Flip 2 Outer Case Disassembly: étape 1, image 1 de 2 JBL Flip 2 Battery Replacement, JBL Flip 2 Outer Case Disassembly: étape 1, image 2 de 2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
  2. JBL Flip 2 Battery Replacement: étape 2, image 1 de 2 JBL Flip 2 Battery Replacement: étape 2, image 2 de 2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
  3. JBL Flip 2 Battery Replacement: étape 3, image 1 de 3 JBL Flip 2 Battery Replacement: étape 3, image 2 de 3 JBL Flip 2 Battery Replacement: étape 3, image 3 de 3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
  4. JBL Flip 2 Battery Replacement: étape 4, image 1 de 2 JBL Flip 2 Battery Replacement: étape 4, image 2 de 2
    • Peel the black rubber piece from one end to the other.
  5. JBL Flip 2 Battery Replacement: étape 5, image 1 de 3 JBL Flip 2 Battery Replacement: étape 5, image 2 de 3 JBL Flip 2 Battery Replacement: étape 5, image 3 de 3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
  6. JBL Flip 2 Battery Replacement: étape 6, image 1 de 3 JBL Flip 2 Battery Replacement: étape 6, image 2 de 3 JBL Flip 2 Battery Replacement: étape 6, image 3 de 3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
  7. JBL Flip 2 Battery Replacement: étape 7, image 1 de 2 JBL Flip 2 Battery Replacement: étape 7, image 2 de 2
    • Expand the metal casing and carefully slide it off the speaker.
  8. JBL Flip 2 Battery Replacement: étape 8, image 1 de 2 JBL Flip 2 Battery Replacement: étape 8, image 2 de 2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
  9. JBL Flip 2 Battery Replacement: étape 9, image 1 de 3 JBL Flip 2 Battery Replacement: étape 9, image 2 de 3 JBL Flip 2 Battery Replacement: étape 9, image 3 de 3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
  10. JBL Flip 2 Battery Replacement: étape 10, image 1 de 3 JBL Flip 2 Battery Replacement: étape 10, image 2 de 3 JBL Flip 2 Battery Replacement: étape 10, image 3 de 3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  11. JBL Flip 2 Battery Replacement: étape 11, image 1 de 2 JBL Flip 2 Battery Replacement: étape 11, image 2 de 2
    • Use the black spudger to disconnect the speaker cord from it's socket.
  12. JBL Flip 2 Battery Replacement: étape 12, image 1 de 2 JBL Flip 2 Battery Replacement: étape 12, image 2 de 2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
  13. JBL Flip 2 Battery Replacement: étape 13, image 1 de 1
    • Carefully remove the cable connecting the control chip to the motherboard.
  14. JBL Flip 2 Battery Replacement: étape 14, image 1 de 2 JBL Flip 2 Battery Replacement: étape 14, image 2 de 2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
  15. JBL Flip 2 Battery Replacement: étape 15, image 1 de 1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
  16. JBL Flip 2 Battery Replacement, Battery: étape 16, image 1 de 2 JBL Flip 2 Battery Replacement, Battery: étape 16, image 2 de 2
    • Remove the one 7.0 mm Phillips #1 screw attaching the motherboard to the casing.
    • Lift the motherboard out of the case to reveal the battery.
  17. JBL Flip 2 Battery Replacement: étape 17, image 1 de 2 JBL Flip 2 Battery Replacement: étape 17, image 2 de 2
    • Remove the cord that connects the ports board to the motherboard.
    • Put the motherboard to the side.
  18. JBL Flip 2 Battery Replacement: étape 18, image 1 de 2 JBL Flip 2 Battery Replacement: étape 18, image 2 de 2
    • Using the black spudger, loosen the brace holding in the battery.
    • To remove the brace, turn it 90 degrees clockwise and lift it up from its socket.
  19. JBL Flip 2 Battery Replacement: étape 19, image 1 de 2 JBL Flip 2 Battery Replacement: étape 19, image 2 de 2
    • Using the black spudger, loosen the battery and remove.
18 autres ont terminé cette réparation.
Jonathan Wear
Membre depuis le 02/09/16
1 220 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 11-2, Cheng Spring 2016
USFT-CHENG-S16S11G2
4 membres
8 tutoriels rédigés
10 commentaires
were i can buy a new battrery?
Joao lemos - Réponse
likea g6 - Réponse
Fanie Schoeman - Réponse
Great guide. Detail was appreciated. I bought my battery at Newegg.com Item#: 9SIA3HK6018406. Thank you.
hale1730 - Réponse
I just managed to find a replacement battery for the older JBL Flip2 , which has a LI-ion battery (just three cables with a different connector) for in this feature just the newer Lipo battery is covered:
This is the right battery for the early version:
https://www.amazon.de/gp/aw/d/B002XCR3UI...
it has a different connector , so soldering the old connector to the new battery is required: Easy enough, since the colors are the same - yellow to yellow , black-black and red-red.
it‘s a tiny bit wider so with a knife the side holders have to be cut out a little, you will see when you receive the battery.
open it up first and you will see which version you have, the LIPo version has the connector at the front as pictured above, the LI-ion version has a 3pin connector at the backside of the PCB.
fir this version you need a LI-ion battery as in the link above.
Everything else is just as described above - ists such a great little speaker and Im happy that it plays again… ;-)
Klaus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 34
30 derniers jours : 162
Total : 32,628
