Introduction
This guide will require the use of a heatgun in the general area of the battery that powers the device, so keep the setting on low and use heat resistant gloves.
Ce dont vous avez besoin
Remove plastic outer housing using hands or a standard spudger.
Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
14 autres ont terminé cette réparation.
5 commentaires
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
The title says replacement, and you show only the removal.
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Change the battery
