Introduction
This guide details how to remove the outer shell and the rubber spine on the speaker. This guide also marks the first steps to access the JBL Flip 4's battery, speakers, circuit boards, etc.
Ce dont vous avez besoin
Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
Pry off the cover, beginning with the side without the volume and bluetooth buttons.
Pull the cover off with your thumbs.
Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
Use the plastic opening tool to release the clips holding the central part of the rubber spine.
Pry away one end of the rubber spine with your thumbs and it should come off.
7 autres ont terminé cette réparation.
