Aller au contenu principal
JBL Flip 5 Outer Case Replacement
Ce dont vous avez besoin
  1. JBL Flip 5 Outer Case Replacement, Outer Case: étape 1, image 1 de 2 JBL Flip 5 Outer Case Replacement, Outer Case: étape 1, image 2 de 2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
  2. JBL Flip 5 Outer Case Replacement: étape 2, image 1 de 1
    • Once all the clips are released, you will be able to pull up that edge of the case.
  3. JBL Flip 5 Outer Case Replacement: étape 3, image 1 de 1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
  4. JBL Flip 5 Outer Case Replacement: étape 4, image 1 de 2 JBL Flip 5 Outer Case Replacement: étape 4, image 2 de 2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
Jackson Tillinghast
Membre depuis le 10/30/23
303 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-5, Konn Fall 2023 Membre de l'équipe UMass Dartmouth, Team 3-5, Konn Fall 2023
UMASSD-KONN-F23S3G5
4 membres
5 tutoriels rédigés
Un commentaire
just wanted to shout out.. coz i got alot of love for this lil speaker.. then one day it just went cactus on me.. sounded like some beloved neighbour had drilled a hole in it or something.. anyways thanks to this guide i opened it up a saw that a screw had some how come loose and was sitting on the speaker.. was such a simple fix but now its good as new. so thank you muchly.. you just made my day!
moist choice - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 46
Total : 296
