Introduction
If you experience any difficulties with charging or playing music through an auxiliary cable, you may need to replace your JBL Pulse 2 speaker's auxiliary and micro USB ports.
Ce dont vous avez besoin
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Use a hot air gun to soften the hot glue in order to fully remove the battery.
So annoying… got to that last step which would have needed some more pictures and guiding to remove the wire… space is too small to remove the wire head part. Looks like everything (USB plug and all) should be removed.
I agree and I'm at that point at this very moment. As a service technician, one trick I have learned is that each of those individual sockets in the plug can be removed. On one side of the plug you will be able to see each individual socket and that each one is held in by a little extruded tab that catches against the plastic connector. If you get a small screwdriver and push on that tab you'll be able to pull that little socket out from the connector. A few words of CAUTION: Do NOT let the exposed connectors touch one other! Also, do NOT let your screwdriver short them out when pushing on the tabs. Work on one at a time, tape them, keep them separated and label them! After they are all removed they can easily be pushed back into the connector again.
I don’t think it’s necessary to remove the battery as long as you unplug it. I don’t see any benefits from this but maybe I’m wrong so someone can clarify? Does removing of the battery give you better access to the aux/usb sockets?
Just because this procedure is for replacing the battery, it is important to remove the old battery.
There was a mountain of hot glue on mine on the battey wires. Since i was replacing the battery anyway, i cut the wires off and made a new hole through the plastic
I like your style!
Remove the solder on the micro USB and Auxiliary port wires to disconnect them.
15 autres ont terminé cette réparation.
8 commentaires
Is there a video out there to demonstrate this repair process?
Hallo, suche für die “JBL pulse 2” die Bauteile FB5 und D9 auf dem Mainboard.
Wer kennt diese Bauteile ?
Würde mich auf eine positive Antwort freuen.
Liebe Grüße J.R.
Bonjour pourriez-vous me dire ou acheter cette petite carte électronique merci.
Hello , il faut d'abord démonter la JBL pour voir le modèle de connecteur car il semblerait qu'il y ait plusieurs modèle , puis faire une recherche "aliexpress Micro USB JBL Pulse2" ... il faut quand même être un peu outillé pour dessouder et surtout ressouder le connecteur .
Bonjour , n'ayant pas la prise usb identique , j'ai mis un petit bout de cable branché sur le + et - et à l'autre extrémité j'ai mis un micro usb sur platine , mais je vais recevoir une femelle USB type C qui est devenue plus courante et je vais la remplacer .
Hello, not having the same USB socket, I put a small piece of cable connected to the + and - and at the other end I put a micro USB on the plate, but I will receive a female USB type C which has become more common and I will replace it.
