Aller au contenu principal
JBL Pulse 2 Button Circuit Board Replacement
Ce dont vous avez besoin
  1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: étape 1, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: étape 1, image 2 de 2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Button Circuit Board Replacement: étape 2, image 1 de 1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Button Circuit Board Replacement: étape 3, image 1 de 1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Button Circuit Board Replacement: étape 4, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement: étape 4, image 2 de 2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Button Circuit Board Replacement: étape 5, image 1 de 3 JBL Pulse 2 Button Circuit Board Replacement: étape 5, image 2 de 3 JBL Pulse 2 Button Circuit Board Replacement: étape 5, image 3 de 3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Button Circuit Board Replacement: étape 6, image 1 de 1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Button Circuit Board Replacement: étape 7, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement: étape 7, image 2 de 2
    • Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Button Circuit Board Replacement: étape 8, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement: étape 8, image 2 de 2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
3 autres ont terminé cette réparation.
Dalton Little
Membre depuis le 08/31/18
254 Réputation
1 tutoriel rédigé
Équipe
3 commentaires
where can I buy that part
Wilco Peters - Réponse
I love you guys
Davi Dodo - Réponse
I need to buy parts
hernzum - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 1,089
