Introduction
The charging port on the JBL Pulse 3 is located on the side of the base by the speakers. It is located among the push buttons on the side of the JBL Pulse 3.
Ce dont vous avez besoin
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
Pull the LED light display off of the JBL Pulse 3 base.
Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
Repeat the steps to take out all three speakers on the base of the JBL Pulse 3.
Using a Phillips #0 screwdriver, remove the 6 mm screw under each of the three speakers around the base of the JBL Pulse 3.
6 autres ont terminé cette réparation.
5 commentaires
And how to put it back with cut cable?
Good very good
I've done a teardown and was able to access the charging terminal without cutting any wires. I didn't have a replacement, so I just put it back together hoping that cleaning it would work. Didn't work.
Yeah its obvious they need to use a C type port they aren't as easy to tear up
You do not have to tear it completely down unless I have a newer version after you take the speaker grill out from around the unit the thin black skeleton like gram that stiffened the grill will actually unclip from the unit with a hook tool or a ice pick that's been heated up and put a slight bend in it take your time because you can break the frame but even if you do its what they make jb weld and gorilla glue for I broke mine but went back together fine after letting the glue set up sprinkled some baking soda on it and made it twice as strong you've only got 4 screws this way cause they well the replacement plug for around $12 don't know why they don't go ahead and use the C type port smh when these came out they was already selling the replacement plug lol
