Aller au contenu principal
JBL Spyro/Spot Partial Disassembly
Ce dont vous avez besoin
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: étape 1, image 1 de 1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: étape 2, image 1 de 1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: étape 3, image 1 de 1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
17 autres ont terminé cette réparation.
Ryan McLeod
Membre depuis le 05/22/10
606 Réputation
2 tutoriels rédigés
11 commentaires
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Réponse
No problem!!
Ryan McLeod -
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Réponse
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 17
30 derniers jours : 103
Total : 13,046
