Aller au contenu principal
JBL Xtreme 3 Battery Replacement
Ce dont vous avez besoin
  1. JBL Xtreme 3 Battery Replacement, Battery: étape 1, image 1 de 1
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: étape 3, image 1 de 2 JBL Xtreme 3 Battery Replacement: étape 3, image 2 de 2
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: étape 4, image 1 de 2 JBL Xtreme 3 Battery Replacement: étape 4, image 2 de 2
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: étape 5, image 1 de 2 JBL Xtreme 3 Battery Replacement: étape 5, image 2 de 2
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: étape 6, image 1 de 3 JBL Xtreme 3 Battery Replacement: étape 6, image 2 de 3 JBL Xtreme 3 Battery Replacement: étape 6, image 3 de 3
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
5 autres ont terminé cette réparation.
Maria
Membre depuis le 09/16/22
472 Réputation
3 tutoriels rédigés
Équipe
Un commentaire
Great guide! Thank you!
dam damo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 37
30 derniers jours : 119
Total : 4,113
