Introduction
This guide will show you how to remove the charging port of a JBL Xtreme. This guide requires soldering skills.
Ce dont vous avez besoin
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
Locate and disconnect the the three plugs indicated in these pictures.
14 autres ont terminé cette réparation.
Un commentaire
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
