Aller au contenu principal
JVC Adixxion GC-XA1BU LCD Cover Replacement
Ce dont vous avez besoin
  1. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery: étape 1, image 1 de 1
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 2, image 1 de 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 3, image 1 de 1
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 4, image 1 de 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 4, image 2 de 2
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 5, image 1 de 1
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU LCD Cover Replacement, Battery Cover: étape 6, image 1 de 1
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: étape 7, image 1 de 2 JVC Adixxion GC-XA1BU LCD Cover Replacement, LCD Cover: étape 7, image 2 de 2
    • Using a 1x1xH1.5 torx screwdriver, remove the 8 screws (5mm headsize / 4mm length) from the corners of both the front and back of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 8, image 1 de 1
    • Carefully lift open the camera from the side of the device with the record and play buttons. Then remove the black cover tape by gently peeling it off. Make sure to save this tape as you may need it when you re-assemble the device.
  9. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 9, image 1 de 3 JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 9, image 2 de 3 JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using the tweezers, carefully push up the left and right sides of the cable ribbon clip. Use the tweezers to life up and remove the clip.
  10. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 10, image 1 de 2 JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 10, image 2 de 2
    • Using the tweezers, carefully remove the ribbon cable by gently grasping it and pulling up.
  11. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 11, image 1 de 1
    • Turn the camera 180 degrees, and gently remove the glue from the connector as shown in the photo. Make sure you save the glue as you may need it when re-assembling your device.
  12. JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 12, image 1 de 3 JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 12, image 2 de 3 JVC Adixxion GC-XA1BU LCD Cover Replacement: étape 12, image 3 de 3
    • Now take out the connector by pulling the white clip out of the casing (as shown in the photos). This will will disconnect the screen from the main cable, allowing you to attach your new LCD cover.
Christina Michelle Johnson
Membre depuis le 01/15/15
1 047 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 345
