Aller au contenu principal
JVC Adixxion GC-XA1BU LCD Screen Replacement
Ce dont vous avez besoin
  1. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 2, image 1 de 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 3, image 1 de 1
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 4, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 4, image 2 de 2
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 5, image 1 de 1
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery Cover: étape 6, image 1 de 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: étape 7, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: étape 7, image 2 de 2
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 8, image 1 de 1
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 9, image 1 de 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 9, image 2 de 3 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 9, image 3 de 3
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 10, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 10, image 2 de 2
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 11, image 1 de 1
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 12, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 12, image 2 de 2
    • Carefully pull the white clip out of the casing using the tweezers.
  13. JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: étape 13, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: étape 13, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
  14. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 14, image 1 de 1
    • Once you have lifted and removed the silver plate, use a Phillips #00 screwdriver to remove the two bottom screws (4mm x 3mm).
  15. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 15, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 15, image 2 de 2
    • Using Tweezers, gently pull the red, black, and white threaded wire to disconnect it, then remove the attached panel as shown.
  16. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: étape 16, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: étape 16, image 2 de 2
    • Carefully lift up and remove the LCD screen using the tweezers.
  17. JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 17, image 1 de 2 JVC Adixxion GC-XA1BU LCD Screen Replacement: étape 17, image 2 de 2
    • The screen as shown if removed properly.
Follow these steps in reverse order with the new LCD screen in order to complete the replacement.
Christina Michelle Johnson
Membre depuis le 01/15/15
1 047 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 13
Total : 785
