Aller au contenu principal
JVC Adixxion GC-XA1BU Lens (External) Replacement
Ce dont vous avez besoin
  1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery: étape 1, image 1 de 1
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 2, image 1 de 1
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 3, image 1 de 1
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 4, image 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 4, image 2 de 2
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 5, image 1 de 1
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery Cover: étape 6, image 1 de 1
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): étape 7, image 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): étape 7, image 2 de 2
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 8, image 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 8, image 2 de 2
    • Twist the metal ring on the lens to the right and then pull it off.
  9. JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 9, image 1 de 2 JVC Adixxion GC-XA1BU Lens (External) Replacement: étape 9, image 2 de 2
    • Use the plastic opening tool to gently pry the lens off of the camera.
Christina Michelle Johnson
Membre depuis le 01/15/15
1 047 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-2, Tanski Winter 2015
USFT-TANSKI-W15S1G2
4 membres
8 tutoriels rédigés
1 commentaire de tutoriel
Where can the lens be purchased at?
Isaac Aguilar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 664
