Aller au contenu principal
JVC KW-V820BT Cooling Fan Removal and Replacement
Ce dont vous avez besoin
  1. JVC KW-V820BT Cooling Fan Removal and Replacement, Front Panel Assembly: étape 1, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Front Panel Assembly: étape 1, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Front Panel Assembly: étape 1, image 3 de 3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Cooling Fan Removal and Replacement: étape 2, image 1 de 2 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 2, image 2 de 2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Cooling Fan Removal and Replacement: étape 3, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 3, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 3, image 3 de 3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Cooling Fan Removal and Replacement: étape 4, image 1 de 1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Cooling Fan Removal and Replacement: étape 5, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 5, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 5, image 3 de 3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Cooling Fan Removal and Replacement, Top Panel Removal: étape 6, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Top Panel Removal: étape 6, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Top Panel Removal: étape 6, image 3 de 3
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Cooling Fan Removal and Replacement, Rear Panel Removal and Replacement: étape 7, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Rear Panel Removal and Replacement: étape 7, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Rear Panel Removal and Replacement: étape 7, image 3 de 3
    • Disconnect Video Out/Rear View Camera cable from circuit board.
    • Remove the Video Out/Rear View Camera cable retaining clip using after removing 0-64 x 3/16" machine screw using a Phillips #0 screwdriver.
    • Withdraw Video Out/Rear View Camera cable from rear panel.
  8. JVC KW-V820BT Cooling Fan Removal and Replacement: étape 8, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 8, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement: étape 8, image 3 de 3
    • Remove the five 1/64 x 3/16" machine screws from the rear panel identified in the photograph.
    • Remove rear panel.
  9. JVC KW-V820BT Cooling Fan Removal and Replacement, Cooling Fan: étape 9, image 1 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Cooling Fan: étape 9, image 2 de 3 JVC KW-V820BT Cooling Fan Removal and Replacement, Cooling Fan: étape 9, image 3 de 3
    • Remove the two 1-64 x 1/2" machine screws and the retaining nuts that fasten the cooling fan to the rear panel using the Phillips #0 screwdriver and the 5/32" socket.
Marshall Andersen
Membre depuis le 10/02/18
665 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 356
