Aller au contenu principal
JVC KW-V820BT Touch Screen Replacement
Ce dont vous avez besoin
  1. JVC KW-V820BT Touch Screen Replacement, Front Panel Assembly: étape 1, image 1 de 3 JVC KW-V820BT Touch Screen Replacement, Front Panel Assembly: étape 1, image 2 de 3 JVC KW-V820BT Touch Screen Replacement, Front Panel Assembly: étape 1, image 3 de 3
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Touch Screen Replacement: étape 2, image 1 de 2 JVC KW-V820BT Touch Screen Replacement: étape 2, image 2 de 2
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Touch Screen Replacement: étape 3, image 1 de 3 JVC KW-V820BT Touch Screen Replacement: étape 3, image 2 de 3 JVC KW-V820BT Touch Screen Replacement: étape 3, image 3 de 3
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Touch Screen Replacement: étape 4, image 1 de 1
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Touch Screen Replacement: étape 5, image 1 de 3 JVC KW-V820BT Touch Screen Replacement: étape 5, image 2 de 3 JVC KW-V820BT Touch Screen Replacement: étape 5, image 3 de 3
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Touch Screen Replacement, Touch Screen: étape 6, image 1 de 3 JVC KW-V820BT Touch Screen Replacement, Touch Screen: étape 6, image 2 de 3 JVC KW-V820BT Touch Screen Replacement, Touch Screen: étape 6, image 3 de 3
    • Remove the power connector gently using tweezers or your fingers.
    • Remove the ribbon cable ZIF connector by flipping the black plastic bar and sliding the ribbon out.
  7. JVC KW-V820BT Touch Screen Replacement: étape 7, image 1 de 3 JVC KW-V820BT Touch Screen Replacement: étape 7, image 2 de 3 JVC KW-V820BT Touch Screen Replacement: étape 7, image 3 de 3
    • Remove the four pan-head 0-80 x 1/8" stainless steel machine screws using the Phillips #00 screwdriver.
    • Remove 2 pan-head 0-80 x 1/8" black finish machines screws using Phillips #00 screwdriver.
    • Remove 2 pan head zinc plated 1/64 x 3/16" machine screws using Phillips #0 screwdriver.
    • Make sure to keep screws of different sizes organized for easier reassembly
  8. JVC KW-V820BT Touch Screen Replacement: étape 8, image 1 de 3 JVC KW-V820BT Touch Screen Replacement: étape 8, image 2 de 3 JVC KW-V820BT Touch Screen Replacement: étape 8, image 3 de 3
    • Remove the metal retaining shroud.
    • Remove the fabric disk drive passage liner.
    • Remove the white plastic button retainer.
  9. JVC KW-V820BT Touch Screen Replacement: étape 9, image 1 de 3 JVC KW-V820BT Touch Screen Replacement: étape 9, image 2 de 3 JVC KW-V820BT Touch Screen Replacement: étape 9, image 3 de 3
    • Remove LCD display.
    • Remove touch-activated side button display.
    • Remove global touch screen assembly.
    • Be careful when handling glass, especially broke glass. It is suggested to wear cut-resistant gloves when handling glass.
2 autres ont terminé cette réparation.
Marshall Andersen
Membre depuis le 10/02/18
665 Réputation
6 tutoriels rédigés
3 commentaires
To whom it may concern,
I successfully replaced the touch screen to my JVC, KW-V820Bt but ran into a small snag.
My screen is back to life but it does not respond to any touch.
Does it need to be calibrated ?
Thank You,
Much Appreciated for any help.
Arturo R.
pantepec00@gmail.com
Arturo Ramirez - Réponse
Hi Arturo, without looking at the device, I can only guess. But, if it doesn’t respond to any touch whatsoever, you might take a second look at the touchscreen component itself (that is the clear glass sheet, step 9, picture 3) and be sure you have that thing connected properly and there is no damage to that little ribbon cable itself. I’m not aware of any calibration procedure, but I could be wrong.
Marshall Andersen - Réponse
Hi
I have a bootloop issue with JVC KW-V820BT
How do I go about finding what is causing it ?
Thanks
Slevin Mclaine - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 25
Total : 4,534
