Aller au contenu principal
JYX-S55 Battery Replacement
Ce dont vous avez besoin
  1. JYX-S55 Battery Replacement, Battery: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the six screws around the perimeter of the top panel of the machine using a 2.5 mm flathead screwdriver.
  2. JYX-S55 Battery Replacement: étape 2, image 1 de 1
    • Grip the top panel with your thumb at the bottom and fingers around the top. Lift the panel until it comes loose.
  3. JYX-S55 Battery Replacement: étape 3, image 1 de 2 JYX-S55 Battery Replacement: étape 3, image 2 de 2
    • Move the top panel backwards and away from you. Let the panel hang down behind the machine, as this will allow you to have access to the components within the machine.
  4. JYX-S55 Battery Replacement: étape 4, image 1 de 1
    • Use a nylon spudger to pry the battery free from the glue.
    • It is important to note do NOT use heat or sharp objects, as the lithium-ion battery is flammable and could potentially explode.
  5. JYX-S55 Battery Replacement: étape 5, image 1 de 1
    • Disconnect the red and black wires from the battery.
    • Remove the battery from the device.
Sarah Iceman
Membre depuis le 02/24/23
445 Réputation
2 tutoriels rédigés
Équipe
Marist, Team 1-5, Chaterdon Spring 2023 Membre de l'équipe Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 membres
4 tutoriels rédigés
3 commentaires
Hi, thanks for the pictures that really helped. What type of battery is needed? Can you email me at vrhaiza@gmail.com.
Rhaiza Villafranca - Réponse
Can you please advise what type of battery would be needed? What if I don't have a nylon spudger? What can I use in exchange?
Jasmine - Réponse
I opened the Karaoke machine:
Lithium-ion
Type- Lithium-ion Battery
Capacity: 3.7V/5200mAh
Model:18650C
Charging limited:4.2V
Date: 2022L1
M
DeniseCabral - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 39
30 derniers jours : 193
Total : 4,950
