Aller au contenu principal
JYX-S55 Speaker Replacement
Ce dont vous avez besoin
  1. JYX-S55 Speaker Replacement, Speaker: étape 1, image 1 de 2 JYX-S55 Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Remove the four screws from the top panel of the device using a 2.5 hex screwdriver.
    • Remove the top panel.
  2. JYX-S55 Speaker Replacement: étape 2, image 1 de 1
    • Remove the four screws that keep the light strip in place using a JIS #1 screwdriver.
  3. JYX-S55 Speaker Replacement: étape 3, image 1 de 2 JYX-S55 Speaker Replacement: étape 3, image 2 de 2
    • Lift out the plastic ring which contains the lights.
    • The lights will be connected with wires. These do not need to be cut or ripped out; simply place the plastic ring off to the side or somewhere out of the way.
  4. JYX-S55 Speaker Replacement: étape 4, image 1 de 1
    • Remove the four screws at the corners of the woofer/speaker using a JIS #1 screwdriver.
  5. JYX-S55 Speaker Replacement: étape 5, image 1 de 1
    • Pull out the speaker’s woofer.
  6. JYX-S55 Speaker Replacement: étape 6, image 1 de 2 JYX-S55 Speaker Replacement: étape 6, image 2 de 2
    • Use a pair of wire cutters to separate the speaker from the rest of the device.
Alexandra Wehrhahn
Membre depuis le 03/04/23
151 Réputation
1 tutoriel rédigé
Équipe
Marist, Team 1-5, Chaterdon Spring 2023 Membre de l'équipe Marist, Team 1-5, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G5
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 33
Total : 283
