Aller au contenu principal
Jabra Elite 85h Speaker Replacement
Ce dont vous avez besoin
  1. Jabra Elite 85h Speaker Replacement, Ear Cushion: étape 1, image 1 de 3 Jabra Elite 85h Speaker Replacement, Ear Cushion: étape 1, image 2 de 3 Jabra Elite 85h Speaker Replacement, Ear Cushion: étape 1, image 3 de 3
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Speaker Replacement, Speaker: étape 2, image 1 de 3 Jabra Elite 85h Speaker Replacement, Speaker: étape 2, image 2 de 3 Jabra Elite 85h Speaker Replacement, Speaker: étape 2, image 3 de 3
    • The foam inserts and backing tape are very delicate. Take your time when removing them, and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Speaker Replacement: étape 3, image 1 de 3 Jabra Elite 85h Speaker Replacement: étape 3, image 2 de 3 Jabra Elite 85h Speaker Replacement: étape 3, image 3 de 3
    • Repeat the previous steps for the other side, removing the foam inserts with care.
  4. Jabra Elite 85h Speaker Replacement: étape 4, image 1 de 1
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Speaker Replacement: étape 5, image 1 de 1
    • Repeat the previous step for the other side, removing the four T6 screws.
  6. Jabra Elite 85h Speaker Replacement: étape 6, image 1 de 1
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
2 autres ont terminé cette réparation.
Matt Gardiner
Membre depuis le 03/15/23
324 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Petersen Spring 2023 Membre de l'équipe UMass Dartmouth, Team 3-4, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G4
4 membres
9 tutoriels rédigés
3 commentaires
Thanks a lot man, I was having some issues with my left side for a while. I assumed it was bad connection since it would return depending on the position and sometimes on non-ANC setup. I just tightened those screws and now it works fine. Cheers.
Alex Fernandes - Réponse
Hi, doughter overturned the speaker. Now the device no longer switches on. can this be fixed again?
Thanks fit your Help.
Regards
Oliver Viboh - Réponse
Where can I get replacement speakers. I know it is 40mm in diameter but what is the ohm and other specifications?
Çağdaş Son - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 70
Total : 1,093
