Aller au contenu principal
Jabra Speak 510 Motherboard Replacement
Ce dont vous avez besoin
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: étape 1, image 1 de 2 Jabra Speak 510 Motherboard Replacement, Outer Casing: étape 1, image 2 de 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: étape 3, image 1 de 2 Jabra Speak 510 Motherboard Replacement: étape 3, image 2 de 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: étape 4, image 1 de 3 Jabra Speak 510 Motherboard Replacement: étape 4, image 2 de 3 Jabra Speak 510 Motherboard Replacement: étape 4, image 3 de 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: étape 5, image 1 de 2 Jabra Speak 510 Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: étape 6, image 1 de 1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: étape 7, image 1 de 2 Jabra Speak 510 Motherboard Replacement: étape 7, image 2 de 2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
4 autres ont terminé cette réparation.
Jordan Murphy
Membre depuis le 02/16/16
717 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 2-3, Harley Spring 2016 Membre de l'équipe IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 membres
8 tutoriels rédigés
3 commentaires
Great walk-through... thanks
Walaa Maher - Réponse
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Réponse
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 21
30 derniers jours : 95
Total : 7,480
