Introduction
The battery is one of the most fundamental components to the JAMBOX MINI. It is used to power the device. Replacing it is very difficult and should only be attempted it absolutely necessary.
Ce dont vous avez besoin
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
I didn’t have a T6 bit. My set only went down to T7. I was able to seat a jeweler’s flat-blade screwdriver into the head, press down firmly, and turn the screw head. Even after breaking the screw loose, there was significant drag to turn it, so be careful of the tool slipping out of the screw head.
Remove all connecting ribbons from the motherboard.
One ZIF or "zero insertion force" ribbon connecting at the side.
One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
I was able to skip steps 6, 7, 8, and 9 after disconnecting only the battery ribbon cable. The battery ZIF socket has a wide black lever that needs to be tilted up from the outside edge to release (and again tilted flat during reassembly to clamp) the cable connection. Skipping steps 6-9 meant that on step 10 I had to remove the battery clip from behind the motherboard that I didn’t remove.
Once the motherboard has been removed, insert a standard metal spudger in between the outer and inner casing of the battery housing.
See also What to get a replacement battery?
I did not find a direct replacement identical battery on the market. I bought a battery for $6 on eBay.
My considerations: The voltage is 3.7V. The storage is at least 900mAh. The mechanical dimensions have to fit inside the compartment. And I selected a two-wire battery because I'm not understanding what the third wire is for so I'm keeping the old power control board and ribbon cable.
There is also a consideration of mass, that needs to match also. I found my new battery with larger dimensions was actually lighter. I will show how to add mass.
The 3rd wire from a battery is usually connected to a thermistor attached to the battery which signals the temperature (resistance value changes with temp) to the battery management circuit in the motherboard.
Charging will be halted to if it got too hot before being fully charged, which may create problems e.g. a fire
If leaving the 3rd wire disconnected, the battery should not be left unsupervised whilst it is charging
Unwrap and conserve the (hopefully functioning) power controller board from the old battery by cutting the tabs. The tabs are thin and soft and cut easily with a razor. Disconnect the positive terminal first. I used a voltmeter to find that the battery case is positive.
I trimmed the tabs about 1/8" from the board, just enough remaining so that I could later fold them over the wires of the new battery.
Cut the connector off of the new battery, ONE WIRE AT A TIME so that you do not short-circuit the battery.
Position the power board approximately and route and trim the wires to length.
Strip and tin the wire ends on the new battery.
Connect the red wire of the new battery to the positive terminal of the board, and the black wire to the negative terminal. You may fold the tab over the wire to hold it while you solder.
Verify the new battery fits in the compartment. I had to omit the battery clip, and exercise care how I routed the wires. Verify the ribbon cable does not need to twist or strain. I had to tuck the power controller well beneath the mother board. Exercise care not to short-circuit the power controller board to the mother board.
Observe that Jawbone did not follow the engineering principle of separation of functions. Jawbone used the battery as the mass in a mass-spring acoustic resonator. So the mass needs to be close to the original. I added a couple of dimes to make up for my new battery being light and discarding the battery clip.
Select a lightweight adhesive. I used tacky glue.
Glue the battery into the compartment
Glue the battery controller board to the battery and position so that the ribbon cable is aligned with the connector. I used a large rubber band (or sponge) between the power controller board and the mother board to temporarily hold position while the glue dried.
Glue the extra mass to the battery
Reconnect the battery cable to the mother board. Tilt the black lever up, slide the cable in, and tilt down firmly.
If you have succeeded, you'll be able to charge the battery while the glue dries.
To reassemble your device, replace the battery and snap the inner casing back into place. Then do the remaining steps in reverse order.
6 autres ont terminé cette réparation.
2 commentaires
Where can you order the replacement battery?
Thanks for the post. I was able to replace my battery and the speaker is functioning fine. I did not desolder the motherboard and didn’t have much trouble getting the old battery out. I did manage to find a battery on Amazon the exact same dimensions and rating and was able to use the factory battery clip. Hardest part of the job is getting the old battery out. Take note where the adhesive tape is when you are doing this job.
I was able to remove the cover without cosmetic damage. I used a 6” sharp knife blade, slid it into the crack and twisted. As Kevin states in Step 2, you are trying to lift up the center of the long edge. The top short end has two tabs and the bottom end has one big tab in the center.
Student4Life - Réponse
Yes I agree with Student4Life. Just insert the spudger into the top short edge (the edge without rubber foot) and you can remove the cover without noteble damage.
Leon - Réponse
