Aller au contenu principal
Jawbone MINI JAMBOX Outer Case Replacement
Ce dont vous avez besoin
  1. Jawbone MINI JAMBOX Outer Case Replacement, Outer Case: étape 1, image 1 de 2 Jawbone MINI JAMBOX Outer Case Replacement, Outer Case: étape 1, image 2 de 2
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
  2. Jawbone MINI JAMBOX Outer Case Replacement: étape 2, image 1 de 1
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
  3. Jawbone MINI JAMBOX Outer Case Replacement: étape 3, image 1 de 1
    • Slide out the rubber foot located on the bottom of the case.
  4. Jawbone MINI JAMBOX Outer Case Replacement: étape 4, image 1 de 1
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
  5. Jawbone MINI JAMBOX Outer Case Replacement: étape 5, image 1 de 3 Jawbone MINI JAMBOX Outer Case Replacement: étape 5, image 2 de 3 Jawbone MINI JAMBOX Outer Case Replacement: étape 5, image 3 de 3
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
Noah Sadler
Membre depuis le 04/01/15
548 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 membres
11 tutoriels rédigés
Un commentaire
Does anyone know where to find replacement outer shells for the big jambox?
aric.valliere - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 3,201
