Aller au contenu principal
Jawbone MINI JAMBOX Speaker Replacement
Ce dont vous avez besoin
  1. Jawbone MINI JAMBOX Speaker Replacement, Outer Case: étape 1, image 1 de 2 Jawbone MINI JAMBOX Speaker Replacement, Outer Case: étape 1, image 2 de 2
    • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
  2. Jawbone MINI JAMBOX Speaker Replacement: étape 2, image 1 de 1
    • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
    • Carefully remove the end panel.
    • The tabs which connect the panel are on the short sides.
    • WARNING: you will likely cause cosmetic damage to the end cap.
  3. Jawbone MINI JAMBOX Speaker Replacement: étape 3, image 1 de 1
    • Slide out the rubber foot located on the bottom of the case.
  4. Jawbone MINI JAMBOX Speaker Replacement: étape 4, image 1 de 1
    • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
    • This is the only flat topped screw in the speaker, so keep track of which one it is.
  5. Jawbone MINI JAMBOX Speaker Replacement: étape 5, image 1 de 3 Jawbone MINI JAMBOX Speaker Replacement: étape 5, image 2 de 3 Jawbone MINI JAMBOX Speaker Replacement: étape 5, image 3 de 3
    • Push against the side without end cap to slide the internal components out of the case.
    • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
    • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
  6. Jawbone MINI JAMBOX Speaker Replacement, Motherboard: étape 6, image 1 de 1
    • Remove all connecting ribbons from the motherboard.
    • One ZIF or "zero insertion force" ribbon connecting at the side.
    • One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
  7. Jawbone MINI JAMBOX Speaker Replacement: étape 7, image 1 de 1
    • Unscrew all four 5mm T6 screws holding the motherboard to the plastic case.
    • Unlike the flat top screw holding the metal housing, these screws are roundtop.
  8. Jawbone MINI JAMBOX Speaker Replacement: étape 8, image 1 de 1
    • Desolder the grounding plug from the motherboard.
    • Make sure your soldering iron is tinned and carefully touch the tip of your iron to the grounding lug. Allow the the solder to liquify. While liquified, lift the motherboard off the grounding lug.
    • WARNING: Do not allow the solder to spill over and bridge any connection on the motherboard.
    • New to soldering? Look at iFixit's soldering guide here.
  9. Jawbone MINI JAMBOX Speaker Replacement: étape 9, image 1 de 1
    • Carefully lift the motherboard out of the plastic housing.
  10. Jawbone MINI JAMBOX Speaker Replacement, Speaker: étape 10, image 1 de 2 Jawbone MINI JAMBOX Speaker Replacement, Speaker: étape 10, image 2 de 2
    • In order to remove the speakers, you must rotate them. Rotate the circled tabs away from their adjacent tabs.
    • Once the speakers are completely rotated, you should see new tabs rotate into sight (see the orange marks).
  11. Jawbone MINI JAMBOX Speaker Replacement: étape 11, image 1 de 1
    • Carefully lift the speaker out of the plastic casing using the rotated metal tabs.
  12. Jawbone MINI JAMBOX Speaker Replacement: étape 12, image 1 de 1
    • Replace the blown speaker with a new one and reassemble the JAMBOX.
5 autres ont terminé cette réparation.
Liam McDonnell
Membre depuis le 04/01/15
559 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-1, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 membres
11 tutoriels rédigés
3 commentaires
where can i buy replacement speakers
Jeffrey S Wardell - Réponse
What is the serial number or supplier for the speakers? Need to buy replacement.
candacec - Réponse
Thank you for the instructions. I was wondering where to start.
Pradeep Mangalagiri - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 22
Total : 5,214
