Introduction
This camcorder only has digital zoom, so there are no components that are physically moving inward and outward. Therefore, in order to fix the zooming ability of the camcorder, you must replace the inner lens.
Ce dont vous avez besoin
Press down on the grooved plastic with your thumbs.
Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
Once you have the back cover off, the camcorder should look like this.
Look on the battery for a model number to assure that you acquire the correct replacement part.
The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
This is the bottom of the camcorder near where the wrist strap connects.
