Aller au contenu principal
Jazz UltraTab C1059-HL Antenna Replacement
Ce dont vous avez besoin
  1. Jazz UltraTab C1059-HL Antenna Replacement, Antenna: étape 1, image 1 de 1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Antenna Replacement: étape 2, image 1 de 1
    • Remove the back panel of the device.
  3. Jazz UltraTab C1059-HL Antenna Replacement: étape 3, image 1 de 1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Antenna Replacement: étape 4, image 1 de 1
    • Identify the antenna cover on the top of the device.
  5. Jazz UltraTab C1059-HL Antenna Replacement: étape 5, image 1 de 1
    • Remove the two screws holding the antenna cover in place.
  6. Jazz UltraTab C1059-HL Antenna Replacement: étape 6, image 1 de 1
    • Use a prying tool to remove the plastic piece off of the antenna component.
  7. Jazz UltraTab C1059-HL Antenna Replacement: étape 7, image 1 de 1
    • Identify the antenna component as the gray cable that comes out of the plastic cover.
  8. Jazz UltraTab C1059-HL Antenna Replacement: étape 8, image 1 de 1
    • Remove all of the adhesive tape pieces off of the antenna cable.
  9. Jazz UltraTab C1059-HL Antenna Replacement: étape 9, image 1 de 1
    • Once all of the adhesive tape has been removed. Pull out the antenna component.
  10. Jazz UltraTab C1059-HL Antenna Replacement: étape 10, image 1 de 1
    • The antenna will be attached to the chip in your device. Be careful not to pull off.
    • Solder of the wire that is connected to the chip in order to be able to remove the antenna component.
    • Once this is done, you can replace your old antenna with a new one!
Amanda Justiniano
Membre depuis le 09/19/15
231 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 1-3, Wilson Fall 2015 Membre de l'équipe IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 207
