Aller au contenu principal
Jazz UltraTab C1059-HL Battery Replacement
Ce dont vous avez besoin
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: étape 1, image 1 de 1
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: étape 2, image 1 de 2 Jazz UltraTab C1059-HL Battery Replacement: étape 2, image 2 de 2
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: étape 3, image 1 de 1
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: étape 4, image 1 de 2 Jazz UltraTab C1059-HL Battery Replacement: étape 4, image 2 de 2
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: étape 5, image 1 de 1
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
Austen Shields
Membre depuis le 09/26/15
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 1-3, Wilson Fall 2015 Membre de l'équipe IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 591
