Aller au contenu principal
Jazz UltraTab C1059-HL Screen Replacement
Ce dont vous avez besoin
  1. Jazz UltraTab C1059-HL Screen Replacement, Screen: étape 1, image 1 de 1
    • First step is to remove screws from top and bottom of device.
  2. Jazz UltraTab C1059-HL Screen Replacement: étape 2, image 1 de 1
    • Remove the back panel of the device.
    • Be careful not to brake/bend the plastic cover of your device.
  3. Jazz UltraTab C1059-HL Screen Replacement: étape 3, image 1 de 1
    • Upon removing the back panel, place the device screen down on the table.
  4. Jazz UltraTab C1059-HL Screen Replacement: étape 4, image 1 de 1
    • Remove all data strips attached to the motherboard.
  5. Jazz UltraTab C1059-HL Screen Replacement: étape 5, image 1 de 3 Jazz UltraTab C1059-HL Screen Replacement: étape 5, image 2 de 3 Jazz UltraTab C1059-HL Screen Replacement: étape 5, image 3 de 3
    • Remove the tape around the battery.
    • One of these pieces of tape holds down the battery connection to the mainboard.
    • Use the soldering iron to disconnect these wires.
    • You will need to use a tool to pry off the battery. It will have a good amount of adhesive holding it down.
    • Be cautious not to bend the battery when prying.
  6. Jazz UltraTab C1059-HL Screen Replacement: étape 6, image 1 de 1
    • Once the battery is removed, make sure to remove any and all data strips that are attached.
    • Then begin to unscrew the mother board.
  7. Jazz UltraTab C1059-HL Screen Replacement: étape 7, image 1 de 1
    • Remove the motherboard chip off of the device.
  8. Jazz UltraTab C1059-HL Screen Replacement: étape 8, image 1 de 1
    • Your board should look like this after taking all of the components off the screen panel.
  9. Jazz UltraTab C1059-HL Screen Replacement: étape 9, image 1 de 2 Jazz UltraTab C1059-HL Screen Replacement: étape 9, image 2 de 2
    • Remove the Display Module from the screen cover.
  10. Jazz UltraTab C1059-HL Screen Replacement: étape 10, image 1 de 1
    • Now, you can replace your broken or damaged screen!
Amanda Justiniano
Membre depuis le 09/19/15
231 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 1-3, Wilson Fall 2015 Membre de l'équipe IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 449
