Aller au contenu principal
Jensen JTA-230 Speaker Replacement
Ce dont vous avez besoin
    • First, open the dust cover and grab it by the hinges and pull up until it slides out.
    • Then, using a screwdriver unscrew the 3 screws on each side and remove the top layer of the record player. The top should pop out.
  1. Jensen JTA-230 Speaker Replacement: étape 2, image 1 de 2 Jensen JTA-230 Speaker Replacement: étape 2, image 2 de 2
    • You should see the speakers(one on both side). From here, you want to unscrew the three screws holding them in place, using the same head as the previous step.
  2. Jensen JTA-230 Speaker Replacement: étape 3, image 1 de 1
    • Carefully remove the speakers from the device, being careful not to harm any components of the speaker.
  3. Jensen JTA-230 Speaker Replacement: étape 4, image 1 de 1
    • Once the speaker is out of the device, you should use a soldering iron to take off the wires on the current broken speaker, and put them to the new speaker using a soldering iron.
John Roche
Membre depuis le 03/02/16
175 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 8-8, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-8, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G8
3 membres
5 tutoriels rédigés
Un commentaire
What type of speakers do I need to buy?
Isaac Bott - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 14
Total : 579
