Aller au contenu principal
Jensen JTA-230 Turntable Platter Replacement
Ce dont vous avez besoin
  1. Jensen JTA-230 Turntable Platter Replacement, Turntable Platter: étape 1, image 1 de 1
    • Remove Cover from record player.
  2. Jensen JTA-230 Turntable Platter Replacement: étape 2, image 1 de 1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Turntable Platter Replacement: étape 3, image 1 de 1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Turntable Platter Replacement: étape 4, image 1 de 1
    • Replace rubber plugs
  5. Jensen JTA-230 Turntable Platter Replacement: étape 5, image 1 de 1
    • Replace Cover
Robert Wilcox
Membre depuis le 03/04/16
227 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 8-8, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-8, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G8
3 membres
5 tutoriels rédigés
Un commentaire
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
ironman175 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 19
Total : 1,676
