Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Jolla C or Intex Aqua Fish Teardown
Ce dont vous avez besoin
  1. Jolla C or Intex Aqua Fish Teardown, Phone & Back Cover: étape 1, image 1 de 2 Jolla C or Intex Aqua Fish Teardown, Phone & Back Cover: étape 1, image 2 de 2
    • Remove the back cover, starting at the bottom right corner with your nail or a prying tool
  2. Jolla C or Intex Aqua Fish Teardown, Battery, Sims & SD: étape 2, image 1 de 2 Jolla C or Intex Aqua Fish Teardown, Battery, Sims & SD: étape 2, image 2 de 2
    • Remove the battery
    • Remove all sim-cards
    • Remove the microSD-card
  3. Jolla C or Intex Aqua Fish Teardown, Middle Cover: étape 3, image 1 de 3 Jolla C or Intex Aqua Fish Teardown, Middle Cover: étape 3, image 2 de 3 Jolla C or Intex Aqua Fish Teardown, Middle Cover: étape 3, image 3 de 3
    • Remove all 14 cross-head screws
    • Use a prying tool to separate the middle cover from the phone, working from the bottom slowly up to the top
    • Watch out for the power and volume buttons, which probably fall out of the device.
  4. Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: étape 4, image 1 de 3 Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: étape 4, image 2 de 3 Jolla C or Intex Aqua Fish Teardown, Top Circuit Board: étape 4, image 3 de 3
    • Remove all cross-head screws
    • Remove the antenna wire from the circuit board
    • Pry loose the power & volume button part at the side (it is stuck to the phone with sticky tape) and pull it out
    • Pull out the connector for the bottom cuircuit board
    • Pull out the screen connector
    • Pry loose the connector for the proximity sensor etc
    • Now you can remove the top circuit board
    • Remove the main and front camera connectors
  5. Jolla C or Intex Aqua Fish Teardown, Bottom Cuircuit Board: étape 5, image 1 de 2 Jolla C or Intex Aqua Fish Teardown, Bottom Cuircuit Board: étape 5, image 2 de 2
    • Remove the antenna cable
    • Remove the speaker and vibration motor from the phone
    • Both items are stuck to the phone and the cables are very fragile. I broke one of the connections when removing the speaker for a second time, as seen in the second picture. It is possible to solder it back on
3 autres ont terminé cette réparation.
Jos Wagenmakers
Membre depuis le 03/20/17
185 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 106
Total : 2,934
