Aller au contenu principal
Joy-Con ZL Switch Replacement
Ce dont vous avez besoin
  1. Joy-Con ZL Switch Replacement, Unscrew the back cover: étape 1, image 1 de 1
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
  2. Outil utilisé dans cette étape :
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  3. Joy-Con ZL Switch Replacement: étape 5, image 1 de 1
    • Resume gameplay!
  4. Joy-Con ZL Switch Replacement, The problem part: étape 6, image 1 de 2 Joy-Con ZL Switch Replacement, The problem part: étape 6, image 2 de 2
    • This tiny piece of metal had come off the small pcb and ribbon cable. In doing so it had jammed the switch.
    • Use the guide for un-jamming ZL switch, to remove the case screws, the top cover and the ZL switch and springs.
  5. Joy-Con ZL Switch Replacement, Splitting it apart: étape 7, image 1 de 3 Joy-Con ZL Switch Replacement, Splitting it apart: étape 7, image 2 de 3 Joy-Con ZL Switch Replacement, Splitting it apart: étape 7, image 3 de 3
    • Having removed the plastic button and 2 springs you uncover the switch and holding screw.
    • Remove the holding screw.
  6. Joy-Con ZL Switch Replacement, Pop out the battery: étape 8, image 1 de 2 Joy-Con ZL Switch Replacement, Pop out the battery: étape 8, image 2 de 2
    • Lift the battery out of the battery chassis tray.Use a plastic splitter if necessary.
    • Do not remove the sticky tape underneath as this is unnecessary. It does not effect the repair.
  7. Joy-Con ZL Switch Replacement, Remove the battery tray: étape 9, image 1 de 2 Joy-Con ZL Switch Replacement, Remove the battery tray: étape 9, image 2 de 2
    • Remove the 4 screws holding down the inner battery support chassis. This exposes the switch connector to the pcb.
    • Note the bottom left screw in this picture is shorter than the others and needs to be put back in the correct aperture.
  8. Joy-Con ZL Switch Replacement, Pulling the plug on the problem....: étape 10, image 1 de 1
    • Gently pull on the ribbon cable to remove the plug from the socket.
    • Insert plug on new ribbon cable & switch.
    • You may need to push in the plug with plastic tweezers. Take care not to damage the cable.
  9. Joy-Con ZL Switch Replacement, Putting it back together: étape 11, image 1 de 1
    • Replace batters chassis tray and screw back into place. Note to put back the shorter screw into the correct hole.
    • Fold battery back into place. Gently push down to get the battery stuck back to the tape.
    • Adjust the ribbon cable to ensure it is not trapped. Place the switch over the alignment pin and screw down the retaining screw.
  10. Joy-Con ZL Switch Replacement, Yippee it works!: étape 12, image 1 de 3 Joy-Con ZL Switch Replacement, Yippee it works!: étape 12, image 2 de 3 Joy-Con ZL Switch Replacement, Yippee it works!: étape 12, image 3 de 3
    • Put the two springs back on their retaining pins and push the button back into place.
    • It should click into place and when you push on the button you should hear the switch click.
    • Fold the cover back over and check there are no trapped wires before screwing back the 4 screws on the cover to complete the repair.
Robin Razzell
Membre depuis le 09/04/13
340 Réputation
2 tutoriels rédigés
1 commentaire de tutoriel
This doesn’t really cover the removal of the ZL/ZR Buttons.
It is good for removing the actual button on the mother board, but not for removing the plastic button on the remote.
OreoDestroyer93 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 79
30 derniers jours : 347
Total : 11,936
