Aller au contenu principal
Juki Chainstitch Machine Thread and Needle Replacement
Ce dont vous avez besoin
  1. Juki Chainstitch Machine Thread and Needle Replacement, Thread and Needle: étape 1, image 1 de 1
    • Pass the thread through the needle eye.
  2. Juki Chainstitch Machine Thread and Needle Replacement: étape 2, image 1 de 1
    • Loop the threading through the two tension posts, making sure you stay in the grooves of the wheels.
  3. Juki Chainstitch Machine Thread and Needle Replacement: étape 3, image 1 de 1
    • Continue the threading, weaving through the pull-off lever.
  4. Juki Chainstitch Machine Thread and Needle Replacement: étape 4, image 1 de 2 Juki Chainstitch Machine Thread and Needle Replacement: étape 4, image 2 de 2
    • Adjust the thread pull-off lever as well as adjust the position of the nipper bar block to the left or the right.
  5. Juki Chainstitch Machine Thread and Needle Replacement: étape 5, image 1 de 1
    • Tighten the thread on the top loop near the nipper releasing knurled thumb nut.
  6. Juki Chainstitch Machine Thread and Needle Replacement: étape 6, image 1 de 1
    • Weave threading through the working arm and have it ready to insert through the eye of the needle.
  7. Juki Chainstitch Machine Thread and Needle Replacement: étape 7, image 1 de 1
    • Again, keep the thread along the groove of the wheel before slipping it through the eye of the needle.
  8. Juki Chainstitch Machine Thread and Needle Replacement: étape 8, image 1 de 1
    • Using the flathead screwdriver, slide the needle up into the slot, with the indented side facing in and tighten until the needle cannot shift.
  9. Juki Chainstitch Machine Thread and Needle Replacement: étape 9, image 1 de 1
    • Insert the thread through the eye of the needle, and you are ready for sewing.
Connor Cherry
Membre depuis le 02/04/19
196 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 138
