Aller au contenu principal
Jumper EZbook S5 Touchpad Replacement
Ce dont vous avez besoin
  1. Jumper EZbook S5 Touchpad Replacement, Touchpad: étape 1, image 1 de 2 Jumper EZbook S5 Touchpad Replacement, Touchpad: étape 1, image 2 de 2
    • Place the laptop so the bottom is facing upwards.
    • Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
  2. Jumper EZbook S5 Touchpad Replacement: étape 2, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 2, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 2, image 3 de 3
    • Detach the battery case using the flat end of a spudger.
  3. Jumper EZbook S5 Touchpad Replacement: étape 3, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 3, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 3, image 3 de 3
    • Pry apart the bottom cover of the laptop using the flat end of a spudger.
  4. Jumper EZbook S5 Touchpad Replacement: étape 4, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 4, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 4, image 3 de 3
    • Remove the four 4 mm screws from the battery using a T3 Torx screwdriver.
  5. Jumper EZbook S5 Touchpad Replacement: étape 5, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 5, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 5, image 3 de 3
    • Flip the battery to the opposite side of the touchpad.
  6. Jumper EZbook S5 Touchpad Replacement: étape 6, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 6, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 6, image 3 de 3
    • Detach the tape on the left side of the touchpad shown in the first two images.
    • Use a heat gun or a hair dryer to melt the glue quickly.
  7. Jumper EZbook S5 Touchpad Replacement: étape 7, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 7, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 7, image 3 de 3
    • Detach the tape on the right side of the touchpad shown in all three images.
    • Use a hair dryer or a heat gun to soften the glue.
  8. Jumper EZbook S5 Touchpad Replacement: étape 8, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 8, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 8, image 3 de 3
    • Use a spudger to detach the touchpad from the top case.
    • The touchpad is attached to the top case with glue. Use a hair dryer or a heat gun to soften the glue.
    • Be patient. Step 8 can take up to 8 hours if you work by yourself.
    • Don't aim the heat gun or the hair dryer anywhere other than the top case.
  9. Jumper EZbook S5 Touchpad Replacement: étape 9, image 1 de 3 Jumper EZbook S5 Touchpad Replacement: étape 9, image 2 de 3 Jumper EZbook S5 Touchpad Replacement: étape 9, image 3 de 3
    • Lift the touchpad out of the case.
2 autres ont terminé cette réparation.
Zed Chen
Membre depuis le 10/25/22
223 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-10, Briggs Fall 2022 Membre de l'équipe CSU Los Angeles, Team 2-10, Briggs Fall 2022
CSULA-BRIGGS-F22S2G10
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 55
Total : 1,429
