Aller au contenu principal
Jura Impressa S model backpanel
Ce dont vous avez besoin
  1. Jura Impressa S model backpanel, How to open a Jura Impressa S model cover: étape 1, image 1 de 2 Jura Impressa S model backpanel, How to open a Jura Impressa S model cover: étape 1, image 2 de 2
    • Always remove the power cord from the wall outlet.
    • Lift out the coffee tray
    • Remove the lid sealing the coffee bean container
    • Remove all of the coffee beans you can possibly remove.
    • Pull the adjuster of the coffee bean grinder straight up
    • Remove the four T15 Torx screws
  2. Jura Impressa S model backpanel: étape 2, image 1 de 2 Jura Impressa S model backpanel: étape 2, image 2 de 2
    • Remove the cup heat plate.
    • It can be opened like a book.
    • Below the cup heat plate there are three more T15 Torx screws. Remove them.
  3. Jura Impressa S model backpanel: étape 3, image 1 de 1
    • The top cover is now free. Lift ´er up and set ´er aside.
  4. Jura Impressa S model backpanel, Jura Impressa S model backpanel: étape 4, image 1 de 3 Jura Impressa S model backpanel, Jura Impressa S model backpanel: étape 4, image 2 de 3 Jura Impressa S model backpanel, Jura Impressa S model backpanel: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    J'achète
    • The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
    • Remove the two oval head screws on the lower edge of the backpanel.
    • Lift the panel up.
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
VauWeh
Membre depuis le 10/19/15
203 187 Réputation
246 tutoriels rédigés
Équipe
Repair is War on Entropy Membre de l'équipe Repair is War on Entropy
Community
25 membres
1 120 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 17
Total : 722
