Introduction
If you want to gain access to inner parts (e.g. pump or heater), you have to remove the backpanel. It is secured by two proprietary screws with oval head.
Ce dont vous avez besoin
Lift out the coffee tray
Remove the lid sealing the coffee bean container
Remove all of the coffee beans you can possibly remove.
Pull the adjuster of the coffee bean grinder straight up
Remove the four T15 Torx screws
Outil utilisé dans cette étape :iFixit Precision 4 mm Screwdriver Bit$2.99
The backpanel is secured with two proprietary screws with oval head. They seem to be rivets, but in fact are screws. The only purpose is, to keep us out of our own devices. You can remove them using an oval drive bit. (Part of some IFixit tool collections or available at a Jura provider or iFixit). In a pitch try needle nose pliers. Here a DIY guide.
Remove the two oval head screws on the lower edge of the backpanel.
Lift the panel up.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
