Introduction
Removing and replacing the solenoid for the drain valve is quite simple. If the drain valve is not opened properly, the most likely failure pattern is as follows: after rinsing, the pressure is not taken from the brew group, the brew group motor continues to try to work, sounds very agonized. This process repeats itself a few times.
Ce dont vous avez besoin
Remove all attachments: water tank, drip tray, aroma lid
Behind the Jura sign are two screws with an oval head. They have to be removed.
These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
This step shows how to remove the top cover
Remove the powder tray and all coffee beans.
The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
Remove the two Phillips screws on the bean container and remove the bean container.
Lift the cover upwards.
The solenoid is secured with a bracket held in place by two Torx T10 screws
Remove the two screws.
Take off the bracket
Take the solenoid out.
Disconnect the cables from the solenoid.
In newer models, there is a drainage motor instead of a magnet. In principle, it is removed in the same way as the magnet. Use these instructions
Remove the two Torx T15 screws on the drain motor and take out the motor. The side with the blue cable is marked with a dot.
First leave the motor connected. Trigger a flush and observe if the pin moves back and forth.
Work through the steps in reverse order to reassemble your device.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
