Aller au contenu principal
Justin Bieber Concert Microphone Speaker Replacement
Ce dont vous avez besoin
  1. Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: étape 1, image 1 de 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Flathead 1.5 mm Screwdriver
    $5.49
    J'achète
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Speaker Replacement, Removing batteries: étape 2, image 1 de 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: étape 3, image 1 de 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: étape 3, image 2 de 2
    • Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Speaker Replacement, Positioning device: étape 4, image 1 de 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: étape 5, image 1 de 2 Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: étape 5, image 2 de 2
    • Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
  6. Justin Bieber Concert Microphone Speaker Replacement, Replacing speaker: étape 6, image 1 de 1
    • Disconnect the speaker wires from the speaker and replace it with the new one
    • Refer to this guide for help with soldering the wires back onto the speaker.
Mike Seyman
Membre depuis le 10/19/14
437 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 4-1, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 7
Total : 182
