Aller au contenu principal
Pour réparer ensemble - Je crée un compte
KLH Speaker Tweeter and Driver Replacement
Ce dont vous avez besoin
  1. KLH Speaker Tweeter and Driver Replacement, Tweeter and Driver: étape 1, image 1 de 1
    • Remove the front speaker mesh to expose the speakers. The mesh will lift off without the use of tools.
  2. KLH Speaker Tweeter and Driver Replacement: étape 2, image 1 de 1
    • Once the mesh is removed, begin to remove the screws securing the small upper speaker/tweeter with a #1 Phillips head screwdriver.
  3. KLH Speaker Tweeter and Driver Replacement: étape 3, image 1 de 1
    • Once the screws have been removed, pry out the small upper speaker with an opening tool.
    • Take care not to damage the speaker’s wooden body while prying the speaker out.
  4. KLH Speaker Tweeter and Driver Replacement: étape 4, image 1 de 1
    • After you have removed the speaker, disconnect the red and brown wires from the speaker.
    • You might require needlenose pliers to do this.
  5. KLH Speaker Tweeter and Driver Replacement: étape 5, image 1 de 3 KLH Speaker Tweeter and Driver Replacement: étape 5, image 2 de 3 KLH Speaker Tweeter and Driver Replacement: étape 5, image 3 de 3
    • Remove the speaker from its plastic bezel using a #1 Phillips head screwdriver.
  6. KLH Speaker Tweeter and Driver Replacement: étape 6, image 1 de 1
    • For the larger bottom speaker, the same steps will be taken to remove the speaker.
    • Remove the four screws securing the speaker.
  7. KLH Speaker Tweeter and Driver Replacement: étape 7, image 1 de 1
    • Once the screws are removed, remove the speaker by either prying up from the top, or pushing the speaker through by pushing on the bottom of the speaker.
  8. KLH Speaker Tweeter and Driver Replacement: étape 8, image 1 de 2 KLH Speaker Tweeter and Driver Replacement: étape 8, image 2 de 2
    • Once the speaker is removed, remove the black and white wires.
2 autres ont terminé cette réparation.
Mark Lee Hensley
Membre depuis le 06/01/16
126 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 28
30 derniers jours : 89
Total : 3,405
