Aller au contenu principal
Pour réparer ensemble - Je crée un compte
KPN Arizona Comfort Replacement
Ce dont vous avez besoin
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: étape 1, image 1 de 3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: étape 1, image 2 de 3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: étape 1, image 3 de 3
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: étape 2, image 1 de 1
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: étape 3, image 1 de 3 KPN Arizona Comfort Replacement: étape 3, image 2 de 3 KPN Arizona Comfort Replacement: étape 3, image 3 de 3
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: étape 4, image 1 de 3 KPN Arizona Comfort Replacement: étape 4, image 2 de 3 KPN Arizona Comfort Replacement: étape 4, image 3 de 3
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: étape 5, image 1 de 3 KPN Arizona Comfort Replacement: étape 5, image 2 de 3 KPN Arizona Comfort Replacement: étape 5, image 3 de 3
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: étape 6, image 1 de 3 KPN Arizona Comfort Replacement: étape 6, image 2 de 3 KPN Arizona Comfort Replacement: étape 6, image 3 de 3
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: étape 7, image 1 de 2 KPN Arizona Comfort Replacement: étape 7, image 2 de 2
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: étape 8, image 1 de 2 KPN Arizona Comfort Replacement: étape 8, image 2 de 2
    • Replace the broken speaker of the phone and solder it back in place.
To reassemble your device, follow these instructions from step 6 in reverse order.
2 autres ont terminé cette réparation.
Maite
Membre depuis le 03/08/17
149 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 62
Total : 1,027
