Introduction
If your Kyvol Cybovac E20 is not cleaning properly, there may be an issue with the side brushes. Side brushes are meant to pick up debris that would be missed otherwise. It is also helpful for cleaning baseboards or wall molding. Check the brushes for any debris and clean them thoroughly. If the brushes still do not work, use this guide to replace them.
Start by placing the vacuum on a flat surface.
Flip the vacuum over with the bumper facing you.
