Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Kambrook 600W Power Drive Blender Disassembly
Ce dont vous avez besoin
    1. Kambrook 600W Power Drive Blender Disassembly, Kambrook 600W Power Drive Blender Disassembly: étape 1, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly, Kambrook 600W Power Drive Blender Disassembly: étape 1, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly, Kambrook 600W Power Drive Blender Disassembly: étape 1, image 3 de 3
      • Firstly, take off lid by twisting anti-clockwise.
      • Remove the glass jar from the blender base by again twisting anti-clockwise.
      Demander à FixBot
      Ajouter un commentaire
    2. Kambrook 600W Power Drive Blender Disassembly: étape 2, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 2, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 2, image 3 de 3
      • The blender blade is attached to a base component at the bottom of the blender jar.
      • To remove the blade, simply twist the attachment according to the direction written, in this case, turning anti-clockwise.
      • The blade could be then easily taken out from the jar, if difficulties occur at this stage, simply adjust the blade's angle when removing so.
      Demander à FixBot
    3. Kambrook 600W Power Drive Blender Disassembly: étape 3, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 3, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 3, image 3 de 3
      • Remove four screws from the base of the blender
      • Take out the ventilation opening from the base. Keep screws aside.
      Demander à FixBot
    4. Kambrook 600W Power Drive Blender Disassembly: étape 4, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 4, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 4, image 3 de 3
      • The clutch is attached to the bottom of the blender. This can be twisted out directly with hand.
      • The disk attached inside the clutch can be pulled out after the clutch is removed from the blender bottom.
      Demander à FixBot
    5. Kambrook 600W Power Drive Blender Disassembly: étape 5, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 5, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 5, image 3 de 3
      • This little component is used to stabilise wires. It can be taken out after cutting the wires.
      Demander à FixBot
    6. Kambrook 600W Power Drive Blender Disassembly: étape 6, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 6, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 6, image 3 de 3
      • Lift out the major electronic part of the blender.
      • Cut off two pieces of wires, then take out the mini light bulb.
      • This is how the blender base should look like at the moment.
      Demander à FixBot
    7. Kambrook 600W Power Drive Blender Disassembly: étape 7, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 7, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 7, image 3 de 3
      • Unscrew the two screws from both sides of the clasp to detach all component, this includes the motor of the blender
      Demander à FixBot
    8. Kambrook 600W Power Drive Blender Disassembly: étape 8, image 1 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 8, image 2 de 3 Kambrook 600W Power Drive Blender Disassembly: étape 8, image 3 de 3
      • Insert wisdom here.
      Demander à FixBot
    9. Kambrook 600W Power Drive Blender Disassembly: étape 9, image 1 de 2 Kambrook 600W Power Drive Blender Disassembly: étape 9, image 2 de 2
      • To take out the back of the of blender speed dial, unscrew two screws that are located opposite each other.
      Demander à FixBot
    10. Kambrook 600W Power Drive Blender Disassembly: étape 10, image 1 de 2 Kambrook 600W Power Drive Blender Disassembly: étape 10, image 2 de 2
      • After taking out the back of the speed dial, the dial will fall out itself.
      • There are three individual pieces that make up the speed dial: the ring, the metal and plastic casting.
      Demander à FixBot
    11. Kambrook 600W Power Drive Blender Disassembly: étape 11, image 1 de 2 Kambrook 600W Power Drive Blender Disassembly: étape 11, image 2 de 2
      • The final disassembly, with all the blender parts and screws, will look like this.
      Demander à FixBot
Angel Lin
Membre depuis le 10/13/18
220 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 73
Total : 6,436
