Introduction
Use this guide to remove and replace the pump assembly on a Karcher Pressure Washers 11073080 2017.
Ce dont vous avez besoin
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 14 mm socket to remove the four bolts securing the pump assembly to the pressure washer.
The new pump assembly will come with a plug in the oil port. After installing the new pump assembly, remove this plug.
Replace the plug with the dipstick from the old pump assembly.
Un commentaire
Estamos interesados en un kit de reconstruccion de una bomba Karcher HD 9/23 DE
Atentamente,
Vicente
