Aller au contenu principal
Kenwood Chef A701A Power Cable Replacement
Ce dont vous avez besoin
  1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: étape 1, image 1 de 2 Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: étape 1, image 2 de 2
    • Turn the mixer upside down
    • Remove the two screws holding the white cable grip.
    • Remove the black cable grip. The long screw also holds the cover onto the terminal block
  2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: étape 2, image 1 de 1
    • Remove the cable cover to expose the terminal block.
    • Remove the wires from the live and neutral terminals.
    • Thread the cables out though the cover and then from the mixer chassis
    • To refit simply follow the removal process in reverse
    • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
    • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
4 autres ont terminé cette réparation.
Grant
Membre depuis le 09/29/15
143 Réputation
1 tutoriel rédigé
Un commentaire
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 94
Total : 9,214
