Aller au contenu principal
Kenwood DNX571HD CD/DVD Drive Replacement
Ce dont vous avez besoin
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 1 de 2 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: étape 1, image 2 de 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: étape 2, image 1 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: étape 2, image 2 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: étape 2, image 3 de 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: étape 3, image 1 de 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: étape 4, image 1 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: étape 4, image 2 de 3 Kenwood DNX571HD CD/DVD Drive Replacement: étape 4, image 3 de 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: étape 5, image 1 de 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: étape 6, image 1 de 2 Kenwood DNX571HD CD/DVD Drive Replacement: étape 6, image 2 de 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Wendy Zaballos
Membre depuis le 09/17/18
952 Réputation
6 tutoriels rédigés
Équipe
Washington State, Team S1-G1, Hope Fall 2018 Membre de l'équipe Washington State, Team S1-G1, Hope Fall 2018
WSU-HOPE-F18S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 23
Total : 1,102
