Aller au contenu principal
Kenwood DRV-N520 Dashcam Motherboard Replacement
Ce dont vous avez besoin
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: étape 2, image 1 de 1
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: étape 3, image 1 de 2 Kenwood DRV-N520 Dashcam Motherboard Replacement: étape 3, image 2 de 2
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: étape 4, image 1 de 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: étape 4, image 2 de 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: étape 4, image 3 de 3
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
Un commentaire
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 215
